[mapguide-users] An exception occurred in DB XML component.
Error: DbSequence::get: Not enough space
Steve Dang
steve.dang at autodesk.com
Fri May 16 18:16:25 EDT 2008
MapGuide does not restrict the amount of objects or sub folders within a repository. The Server performs/protects a Load Package operation within a single transaction. The bigger the package is, the more memories/time are required. Try to break the package into smaller ones, then run them sequentially.
Steve.
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Rock Beans
Sent: Friday, May 16, 2008 3:00 PM
To: MapGuide Users Mail List
Subject: [mapguide-users] An exception occurred in DB XML component. Error: DbSequence::get: Not enough space
What does this error mean when loading a 103MB package? I am using the 2.0.1 version of MapGuide OS. The log was about 27,000 lines long before this error came up. Is there a limit to the amount of objects or sub folders within a repository? Any info would be great as we are gearing up a BIG corporate customer for you guys (Autodesk).
Error from MapAdmin: An exception occurred in DB XML component. Error: DbSequence::get: Not enough space
The Rock
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080516/0a2ea4b0/attachment.html
