[mapguide-users] Loading Packages Error on Missing DWF
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Sat May 17 07:15:50 EDT 2008
There should be an error message in the log, describing the problem.
If not, you can enable the TRACE log (which will slow the server quite a
bit), and see the last operation and parameters there.
You might also try to upload the package through the http interface:
http://localhost/mapguide/mapagent/index.html
Once you figure out what the problem is, you can fix the package by
doing this:
1. Rename from .mgp to .zip
2. Extract to a folder
3. Edit the file MgResourcePackageManifest.xml and remove the broken item
4. Update the .zip file
5. Rename back to .mgp
Regards, Kenneth Skovhede, GEOGRAF A/S
Rock Beans skrev:
> Is there any way for the log to say what file is actually missing. We
> have a client that is loading 150MB packages at times and when you get
> this error is very frustrating. How do you know what went wrong? If
> you don't know what DWF is missing how can you fix? Right now my only
> answer is sorry you wasted your time for the past 2 weeks restore an
> older package and start over. There has to be a better way. Anyone
> else deal with bad packages or something similar to this?
> The Rock
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080517/03a6a6e7/attachment.html
