[mapguide-users] MapStudio Open Source - MgDbXmlException
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Mon May 26 08:50:33 EDT 2008
When that happens, it is because the Xml is not valid.
In the server log, there is a more detailed description of the error:
C:\program files\MapGuideOpenSource2.0\server\logs\error.log
Using that information, you may be able to guess what the problem is.
If you figure it out, please let me know
If not, can you explain, step by step, what you did to produce this error?
I would appreciate it if you created a ticket for this problem:
http://trac.osgeo.org/mapguide/newticket
In the component field, make sure you select "Maestro" (that is the new
name for MapStudio OS).
Regards, Kenneth Skovhede, GEOGRAF A/S
geofleming skrev:
> I am also getting this error when trying to make a map.
> I have tried different data, even tried the sheboygan sdf files but still
> nothing. Is it a rights issue on the server? Something not registered? I
> have installed mapguide os on both a win 2003 server and Xp pro using the
> bundles software and the demo data works great but thats all that works.
> Thanks for any help.
> Kevin
> Viva_Rose wrote:
>> i having this error when i try to save the xxxx.map
>> Wat should i do to prevent this error....
>> http://www.nabble.com/file/p17097041/Error.bmp
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080526/7fa799ba/attachment.html
