[ZS1] Re: [mapguide-users] raster help - seriously....
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Tue May 27 11:28:14 EDT 2008
I have rasters (GDAL/ECW) working in 2.0.
The procedure I took was this:
1. Install MgServer
2. Install MgWebExt
3. Stop MapGuide service
4. Remove FDO folder (C:\Program files\MapGuideOpenSource\Server\Bin\FDO)
5. Download win32 FDO SDK here:
http://fdo.osgeo.org/content/fdo-331-downloads#3.3.1_win_binaries
6. Untar (that is extract) the files.
7. Rename folder "bin" to FDO
8. Place the FDO folder instead of the one deleted in step 4
9. Download ECW plugin from here:
http://trac.osgeo.org/fdo/wiki/FdoGdalNotes#MrSIDandECWPluginSupportWindows
Well actually, select "ecw" here http://home.gdal.org/dl/gdal14_vc8/
10. Place the "gdalplugins" folder in C:\Program
files\MapGuideOpenSource\Server\Bin, this gives a final path like this:
C:\Programmer\MapGuideOpenSource2.0\Server\Bin\gdalplugins\gdal_ECW.dll
11. Restart the MapGuide service.
I assume the same holds for mrsid.
Regards, Kenneth Skovhede, GEOGRAF A/S
mrsyer skrev:
> Hey Andrew, I've suffered the same problem on 2.0. I didn't migrate this was
> my first use of open source. See my problem under the thread 'repairing open
> source'. Anyways I tried using this solution from the rasters.zip folder,
> but then I couldn't read any of my data, now I can't log into my site or
> uninstall the program so beware if you do use the rasters.zip. Anyways good
> luck.
