[mapguide-users] Move Default Repository Location?
JeffJensen
jefferyjjensen at gmail.com
Thu Oct 2 16:51:03 EDT 2008
Hello Jason,
Thanks.
With regard to the SQLite Provider.
I'm using FME Workbench to create my SDF3 files. Once I setup the alias on
the MapGuide Server, I use MapGuide Studio -> Site Explorer, right click on
a folder and choose New -> Data Connection...
I then select a feature provider, in my case OSGeo FDO Provider for SDF
Are you saying I can use the SQLite Provide instead of the OSGeo FDO
Provider for SDF?
Or are you saying, don't use SDF3 files, but load the data into SQLite
instead?
Thanks for the clarification.
Jeff Jensen
JasonBirch wrote:
> I was actually wondering about that recommendation myself.
> I personally haven't seen any noticeable performance degradation when
> using unmanaged SDF files, but this is subjective and I generally have
> less than a dozen SDF files in each directory, organised by subject
> area. Zac has more experience with large data sets than I do, so I
> could easily be wrong on this. For my use case, the convenience of
> unmanaged data outweighs any measurable, but to me unnoticeable,
> performance degradation.
> Unmanaged SHP files are apparently a different issue, where the data
> source schema is built per-directory rather than per-file, but I don't
> have any experience with this. I think you can get around this by
> storing a very limited number of SHP files per directory.
> If you are really concerned about performance, the beta SQLite provider
> is noticeably faster than the SDF provider, though it has fewer
> features. I'll see if I can find time to put together a current build
> of this for MapGuide 2.0.2.
> Jason
> -----Original Message-----
> From: JeffJensen
> Subject: RE: [mapguide-users] Move Default Repository Location?
> I like the idea of using unmanaged data sets but I'm not sure if this
> will
> slow down MapGuide. According to the web log at
> http://zacster.blogspot.com/2008/10/mapguide-performance-tips.html #3
> Always
> use Managed Resources, that is SDF's uploaded into the repository.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/Move-Default-Repository-Location--tp8714272p19787378.html
