[mapguide-users] MapGuide Open Source 2.0.2 released
Tom Fukushima
tom.fukushima at autodesk.com
Wed Sep 24 11:59:05 EDT 2008
With regard to version sensitivity: The build is not sensitive to the Java version; the latest version can always be used. I think it is sensitive in some way to Apache 2.2 because of the Apache module we create. It definitely seems sensitive to PHP; I doubt that anything outside of PHP 5.2 will work.
Changes to PROJ and GDAL libraries seem to go without a hitch so I wouldn't be surprised if any version could be used here.
Tom
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Frank Warmerdam (External)
Sent: Tuesday, September 23, 2008 1:17 PM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] MapGuide Open Source 2.0.2 released
Jason,
First, note that packaging for OSGeo4W does not involve any need to
modify the installer program. All you do is package .tar.bz2 files
with the stuff to install, write a "setup.hint" text file declaring
dependencies, and include post install actions in your .tar.bz2 file
as a .bat file.
OSGeo4W is currently using PROJ 4.6.x and GDAL 1.5.2. It also already
includes a packaged Apache, Java and PHP.
It is possible to package copies of some of these things for MapGuide
if it helps expedite things, but the long term goal would be to share
as many underlying components as possible rather than including copies
in a specific package like MapGuide.
I *believe* that MapGuide is not really so sensitive to PROJ.4 and
GDAL versions as it thinks it is. :-) I wouldn't be surprised if
it is more sensitive with regard to Java, PHP and Apache.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
