[mapguide-users] c#.Net displaying problem
Jackie C. Ng
jumpinjackie at gmail.com
Thu Sep 25 03:45:47 EDT 2008
Are you able to get the resource id of the points feature source? If so, you
can use the schema report to preview this feature source and see if it
contains any features.
- Jackie
Viva_Rose wrote:
> Hello,
> I am having a problem with displaying points that I have created during
> runtime. I can create the featuresource, create the layer using a XML
> file, add the layer to the map and after that I add a point to the empty
> layer, set the layer visible and force to refresh, and finally save the
> map; I have controlled the steps of my source according to the examples in
> the dotnetviewer sample application (findaddress.aspx etc.).
> Nevertheless the point is not shown in map display after a map refresh,
> but in the legend the new layer is visible, the style is shown correctly,
> I can read the point in source code using a feature reader and I do not
> have any error messages.
> Has anybody some ideas what I am doing wrong, am I missing something ?
> My configuration: MgOS 2.0.0, .Net environment, source in C#
> Thanks advance,
> Viva
http://themapguyde.blogspot.com
http://www.linkedin.com/in/jackieng
View this message in context: http://www.nabble.com/c-.Net-displaying-problem-tp19664218p19664605.html
