[mapguide-users] Popup window
Stefan Dalakov
s.dalakov at mapware.net
Wed Apr 1 09:33:25 EDT 2009
I am still not quite sure what you are trying. I understand now that you
want to select a parcel, retrieve data for it and open a window, using
some of its parameters, or update them.
This can be found step by step in MG Developer's Guide (DevGuide.pdf,
which you have with your installation) - page 45 - Active Selections.
There is a saying, that one month of efforts to do something , saves you
half an hour of reading the documentation. In your case I think it is a
bit worse - This topic appears for a long time and the reading will take
not more than 15 min.
Stefan Dalakov
padmini godavarthi wrote:
> Hi,
> Thanku very much for ur reply.
> really thanks once again because i could not find the path for this popup window
> Actually my requirement is that i need to save the owner image of that particular parcel (polygon) in the layer.
> so i thought i put a owner icon on taskbar while clicking that icon and selecting feature(parcel) on the layer
> a pop up window will have to open
> but really iam unable to find this !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
> is it could be done with invoke script????????/
> by using invoke url iam able to get the my custom page in task pane.
> But i want a pop up window
> can u plz tell me the solution
> Have you tried this :
> 1. Place the links to be activated in a field
> 2. In studio or Maestro, in Layer definition, set this field against
> "URL activated for feature".
> Then in viewer when you place the pointer on top of the feature you will
> see "Ctrl+click to open link ...<the contents of the field>...
> No need to say that you may construct a more complex link in maestro or
> studio as expression including more fields or constants
> Is this what you need ?
> Stefan Dalakov
>> Hi,
>> no seriously!!!!!!!!!!!!!!
>> i didnt know to invoke pop up window
>> i tried a lot but iam unable to do it.
>> Thanks
>> Padmini.
>> I tought that was 1st April joke :)
>> -----Original Message-----
>> From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
>> Sent: Wednesday, April 01, 2009 8:16 AM
>> To: MapGuide Users Mail List
>> Subject: Re: [mapguide-users] Popup window
>> YET AGAIN,
>> have you tried search the mailing archives.....?
>> z
>> On Wed, Apr 1, 2009 at 5:07 PM, padmini godavarthi
>> <godavarthi.padmini at gmail.com> wrote:
>>> Hi,
>>> i want to invoke popup a window while clicking the feature after selecting the feature.
>>> is it done by invoke url? or invoke script ?
>>> how is it possible???????
>>> plz if possible try to send me the sample code.
>>> Thanks in advance
>>> Regards,
>>> Padmini.
>>> View this message in context: http://n2.nabble.com/Popup-window-tp2567330p2567330.html
>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
