[mapguide-users] Next beta release date?
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Tue Aug 18 02:47:48 EDT 2009
There are two things mixing up in Maestro.
Usually the "no identity properties" is a warning and only gets
displayed when the user invokes the validation.
But in this case the call itself throws an exception, which usually
happens when the FeatureSource is broken,
and thus it gets displayed to the user.
You can safely ignore it, as it is not a problem with your
FeatureSource, it is a bug in MapGuide.
The bug should not affect fusion or the AJAX viewer, because they use
the WebTier API,
and apparently the bug is only in the HTTP Web API that Maestro uses.
Regards, Kenneth Skovhede, GEOGRAF A/S
Ed Jobe skrev:
> In your ticket, you said that repository validation failed after this
> error. I assumed other things failed as well, because in my maps, I
> was unable to get parts of the flexible layout templates to display.
> The secondary toolbar and the file menu toolbar did not display and in
> the taskpane, the tasks button did not work.
> Ed Jobe
> *From:* Jason Birch <Jason.Birch at nanaimo.ca>
> *To:* MapGuide Users Mail List <mapguide-users at lists.osgeo.org>
> *Sent:* Monday, August 17, 2009 8:42:26 AM
> *Subject:* RE: [mapguide-users] Next beta release date?
> Thanks Ed,
> I think that you should be able to safely ignore that error and
> continue saving the datasets. I believe (and Kenneth could probably
> confirm this) that it's just testing to ensure that there is a primary
> key that you can use to select data.
> Jason
> *From:* Ed Jobe
> *Sent:* Monday, August 17, 2009 7:18 AM
> *Subject:* Re: [mapguide-users] Next beta release date?
> Jason
> Trac 1601 is the problem I was having. Since it caused Maestro to
> fail, I wasn't able to proceed any further.
> Ed Jobe
> mapguide-users mailing list
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090818/bd064b52/attachment.html
