[mapguide-users] Should I give up?
Mark Pendergraft markp at Meadgilman.com
Wed Dec 9 14:36:38 EST 2009
Kenneth,
I attempted to add the NASA site
(http://wms.jpl.nasa.gov/wms.cgi?service=wms&version-1.1.1) as a WMS and
yes, I was able to save the Feature Source by pressing "YES" on the error
dialog, and yes i'm unable create a layer with Raster geometry.  All this
using 2.1 and the Maestro Preview.
Thanks for your help.
-Mark P.
Kenneth Skovhede, GEOGRAF A/S wrote:
> I have commented on the issue created (or attempted to, since trac is
> not responding):
>> The many messages are reported in issue #1149.
>> The dialog is actually a message like:
>> Errors detected, save anyway?
>> So, you can just press enter, and it should save just fine.
>> The error message is a defect in MapGuide (issue #1061), which should
>> have been fixed in 2.1 release.
> The reason you are not seeing the the messagebox in the older version of
> Maestro is because
> the resource validator was not implemented then. I recommend sticking to
> the preview, as it
> has multiple bugfixes, and you can get around your current issue by
> pressing .
> For your next issue, the featuresource is a WMS type, which means that
> the output is a raster type. For some reason the layer editor displays
> the vector layer editor. Since there is no vector data, you cannot
> select a geometry column.
> I have no idea why the WMS featuresource would be interpreted as a
> vector featuresource,
> but if the featuresource you are using is the nasa one, I can test it
> and hopefully fix it in a few days.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> Jason Birch skrev:
>> Can you please file that as a bug against the Maestro component in the
>> MapGuide Trac so that it can be easily addressed by Kenneth?  Please
>> include details such as the WMS site you were connecting to and the
>> error message received.
>> I still heartily recommend using the current Maestro test build for
>> those who aren't affected by this bug. The theming and expression
>> editor enhancements alone make it more than worthwhile as long as
>> there are no showstoppers for your use case.t
>> On 2009-12-08, Neil_w  wrote:
>>> Installing the current version of Maestro solves the WMS connection
>>> problem.
>>> What an aggravation that was!
>>> I'm still not able to view a feature from the service though. None of
>>> the
>>> feature classes have any Geometry. Please note the screen capture again.
>>> Are
>>> you getting anything?
>>> http://screencast.com/t/OTcyMDA0Y
>>> View this message in context:
>>> http://n2.nabble.com/Should-I-give-up-tp4128103p4133885.html
>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
http://n2.nabble.com/file/n4141498/Maestro%2BLayer%2BError.png
View this message in context: http://n2.nabble.com/Should-I-give-up-tp4128103p4141498.html
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20091209/bee25cf1/attachment.html
