[mapguide-users] Should I give up?
Kenneth Skovhede ks at geograf.dk
Sat Dec 12 05:06:56 EST 2009
Hi Mark, thanks for verifying this.
I have found and fixed the bug, details are in issue #1189:
http://trac.osgeo.org/mapguide/ticket/1189
Regards, Kenneth Skovhede, GEOGRAF A/S
Mark Pendergraft skrev:
> Kenneth, I attempted to add the NASA site
> (http://wms.jpl.nasa.gov/wms.cgi?service=wms&version-1.1.1) as a WMS
> and yes, I was able to save the Feature Source by pressing "YES" on
> the error dialog, and yes i'm unable create a layer with Raster
> geometry. All this using 2.1 and the Maestro Preview. Thanks for your
> help. -Mark P.
>     Kenneth Skovhede, GEOGRAF A/S wrote:
>     I have commented on the issue created (or attempted to, since trac
>     is not responding):
>         The many messages are reported in issue #1149. The dialog is
>         actually a message like: Errors detected, save anyway? So, you
>         can just press enter, and it should save just fine. The error
>         message is a defect in MapGuide (issue #1061), which should
>         have been fixed in 2.1 release.
>     The reason you are not seeing the the messagebox in the older
>     version of Maestro is because the resource validator was not
>     implemented then. I recommend sticking to the preview, as it has
>     multiple bugfixes, and you can get around your current issue by
>     pressing . For your next issue, the featuresource is a WMS type,
>     which means that the output is a raster type. For some reason the
>     layer editor displays the vector layer editor. Since there is no
>     vector data, you cannot select a geometry column. I have no idea
>     why the WMS featuresource would be interpreted as a vector
>     featuresource, but if the featuresource you are using is the nasa
>     one, I can test it and hopefully fix it in a few days. Regards,
>     Kenneth Skovhede, GEOGRAF A/S Jason Birch skrev: > Can you please
>     file that as a bug against the Maestro component in the > MapGuide
>     Trac so that it can be easily addressed by Kenneth? Please >
>     include details such as the WMS site you were connecting to and
>     the > error message received. > > I still heartily recommend using
>     the current Maestro test build for > those who aren't affected by
>     this bug. The theming and expression > editor enhancements alone
>     make it more than worthwhile as long as > there are no
>     showstoppers for your use case.t > > On 2009-12-08, Neil_w wrote:
>     > >> Installing the current version of Maestro solves the WMS
>     connection problem. >> What an aggravation that was! >> >> I'm
>     still not able to view a feature from the service though. None of
>     the >> feature classes have any Geometry. Please note the screen
>     capture again. Are >> you getting anything? >> >>
>     http://screencast.com/t/OTcyMDA0Y >> >> -- >> View this message in
>     context: >>
>     http://n2.nabble.com/Should-I-give-up-tp4128103p4133885.html >>
>     Sent from the MapGuide Users mailing list archive at Nabble.com.
>     >> _______________________________________________ >>
>     mapguide-users mailing list >> mapguide-users at lists.osgeo.org >>
>     http://lists.osgeo.org/mailman/listinfo/mapguide-users >> >> >
>     _______________________________________________ > mapguide-users
>     mailing list > mapguide-users at lists.osgeo.org >
>     _______________________________________________ mapguide-users
>     mailing list mapguide-users at lists.osgeo.org
> View this message in context: Re: Should I give up?
> <http://n2.nabble.com/Should-I-give-up-tp4128103p4141498.html>
> <http://n2.nabble.com/MapGuide-Users-f1803227.html> at Nabble.com.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20091212/439a2577/attachment.html
