[mapguide-users] Should I give up?
Kenneth Skovhede
ks at geograf.dk
Sat Dec 12 20:26:44 EST 2009
FYI: I have put up Maestro r4431 which fixes the WMS issues.
Regards, Kenneth Skovhede, GEOGRAF A/S
Kenneth Skovhede skrev:
> Hi Mark, thanks for verifying this.
> I have found and fixed the bug, details are in issue #1189:
> http://trac.osgeo.org/mapguide/ticket/1189
> Mark Pendergraft skrev:
>> Kenneth, I attempted to add the NASA site
>> (http://wms.jpl.nasa.gov/wms.cgi?service=wms&version-1.1.1) as a WMS
>> and yes, I was able to save the Feature Source by pressing "YES" on
>> the error dialog, and yes i'm unable create a layer with Raster
>> geometry. All this using 2.1 and the Maestro Preview. Thanks for your
>> help. -Mark P.
>> Kenneth Skovhede, GEOGRAF A/S wrote:
>> I have commented on the issue created (or attempted to, since
>> trac is not responding):
>> The many messages are reported in issue #1149. The dialog is
>> actually a message like: Errors detected, save anyway? So,
>> you can just press enter, and it should save just fine. The
>> error message is a defect in MapGuide (issue #1061), which
>> should have been fixed in 2.1 release.
>> The reason you are not seeing the the messagebox in the older
>> version of Maestro is because the resource validator was not
>> implemented then. I recommend sticking to the preview, as it has
>> multiple bugfixes, and you can get around your current issue by
>> pressing . For your next issue, the featuresource is a WMS type,
>> which means that the output is a raster type. For some reason the
>> layer editor displays the vector layer editor. Since there is no
>> vector data, you cannot select a geometry column. I have no idea
>> why the WMS featuresource would be interpreted as a vector
>> featuresource, but if the featuresource you are using is the nasa
>> one, I can test it and hopefully fix it in a few days. Regards,
>> Kenneth Skovhede, GEOGRAF A/S Jason Birch skrev: > Can you please
>> file that as a bug against the Maestro component in the >
>> MapGuide Trac so that it can be easily addressed by Kenneth?
>> Please > include details such as the WMS site you were connecting
>> to and the > error message received. > > I still heartily
>> recommend using the current Maestro test build for > those who
>> aren't affected by this bug. The theming and expression > editor
>> enhancements alone make it more than worthwhile as long as >
>> there are no showstoppers for your use case.t > > On 2009-12-08,
>> Neil_w wrote: > >> Installing the current version of Maestro
>> solves the WMS connection problem. >> What an aggravation that
>> was! >> >> I'm still not able to view a feature from the service
>> though. None of the >> feature classes have any Geometry. Please
>> note the screen capture again. Are >> you getting anything? >> >>
>> http://screencast.com/t/OTcyMDA0Y >> >> -- >> View this message
>> in context: >>
>> http://n2.nabble.com/Should-I-give-up-tp4128103p4133885.html >>
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> >> _______________________________________________ >>
>> mapguide-users mailing list >> mapguide-users at lists.osgeo.org >>
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users >> >> >
>> _______________________________________________ > mapguide-users
>> mailing list > mapguide-users at lists.osgeo.org >
>> _______________________________________________ mapguide-users
>> mailing list mapguide-users at lists.osgeo.org
>> View this message in context: Re: Should I give up?
>> <http://n2.nabble.com/Should-I-give-up-tp4128103p4141498.html>
>> <http://n2.nabble.com/MapGuide-Users-f1803227.html> at Nabble.com.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20091213/17c33a09/attachment.html
