[mapguide-users] Should I give up?
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Wed Dec 9 05:13:39 EST 2009
I have commented on the issue created (or attempted to, since trac is
not responding):
<quote>
The many messages are reported in issue #1149.
The dialog is actually a message like:
Errors detected, save anyway?
So, you can just press enter, and it should save just fine.
The error message is a defect in MapGuide (issue #1061), which should
have been fixed in 2.1 release.
</quote>
The reason you are not seeing the the messagebox in the older version of
Maestro is because
the resource validator was not implemented then. I recommend sticking to
the preview, as it
has multiple bugfixes, and you can get around your current issue by
pressing <enter>.
For your next issue, the featuresource is a WMS type, which means that
the output is a raster type. For some reason the layer editor displays
the vector layer editor. Since there is no vector data, you cannot
select a geometry column.
I have no idea why the WMS featuresource would be interpreted as a
vector featuresource,
but if the featuresource you are using is the nasa one, I can test it
and hopefully fix it in a few days.
Regards, Kenneth Skovhede, GEOGRAF A/S
Jason Birch skrev:
> Can you please file that as a bug against the Maestro component in the
> MapGuide Trac so that it can be easily addressed by Kenneth?  Please
> include details such as the WMS site you were connecting to and the
> error message received.
> I still heartily recommend using the current Maestro test build for
> those who aren't affected by this bug. The theming and expression
> editor enhancements alone make it more than worthwhile as long as
> there are no showstoppers for your use case.t
> On 2009-12-08, Neil_w <nwilson at sec-landmgt.com> wrote:
>> Installing the current version of Maestro solves the WMS connection problem.
>> What an aggravation that was!
>> I'm still not able to view a feature from the service though. None of the
>> feature classes have any Geometry. Please note the screen capture again. Are
>> you getting anything?
>> http://screencast.com/t/OTcyMDA0Y
>> View this message in context:
>> http://n2.nabble.com/Should-I-give-up-tp4128103p4133885.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20091209/e87fa98a/attachment.html
