[mapguide-users] Layer schema - how to enforce version?
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Sat Feb 14 06:31:50 EST 2009
On this page, you can see what changes are included in the different
versions:
http://trac.osgeo.org/mapguide/wiki/MapGuideRfcs
If you don't need the features from the newer version, you don't have to
upgrade.
You can use the "Edit as Xml" button and manually set the version number.
Maestro has a number of templates in the installation folder, you can
edit the version
number there to force new layers to use another version, or add one with
a specific version.
Regards, Kenneth Skovhede, GEOGRAF A/S
miansi skrev:
> Hello,
> I am using FDO 3.3.2 to get data from SQL 2008 and show it on the map.
> MGOS v2.0.2
> I created dataconnection and layer manually and add layer to the map and
> pointed layout to the map I created.
> Everything fine, but if I choose "Edit layer in XML editor" from Maestro I
> see:
> <LayerDefinition xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xmlns:xsd="http://www.w3.org/2001/XMLSchema"
> xsi:noNamespaceSchemaLocation="LayerDefinition-1.1.0.xsd" version="1.1.0">
> I noticed that in the C:\Program Files\MapGuideOpenSource2.0\Server\Schema
> folder there is 3 schemas for layers:
> LayerDefinition-1.0.0.xsd
> LayerDefinition-1.2.0.xsd
> Why schema version is 1.1.0 and not 1.2.0?
> How can I enforce it?
> Should I?
> Thank you
