[mapguide-users] 100 usd Coordinate System Initialization Problem
Zac Spitzer
zac.spitzer at gmail.com
Tue Jan 13 07:29:11 EST 2009
hey that's good to hear, hope it works out!
if you want to do something for the overall project, there is a build
environment being setup
at home for one of the Autodesk developers for the open source side of
the project.
there are some notes about it on the wiki
http://trac.osgeo.org/mapguide/wiki/PscMeeting01-08-2009
z
On Tue, Jan 13, 2009 at 11:23 PM, aare.pikaro at gmail.com
<aare.pikaro at gmail.com> wrote:
> It seems that the winner of this task is unfortunately Autodesk support. Most
> likely I wont pay them for this fix since they are already charging our firm
> for technical support. :)
> But the solution was pretty simple. Autodesk support noticed that our
> mapguide server was not patched to Update1, which should have been of
> version 34.2 and not 32.2. At the same time web server extensions were
> updated to Update1. So the most likely cause for my problems is incompatible
> versions. I just hope that solves our coordinate initialization problems.
> View this message in context: http://n2.nabble.com/100-usd-Coordinate-System-Initialization-Problem-tp2144513p2150873.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer -
http://zacster.blogspot.com
+61 405 847 168
