[mapguide-users] Postgis/mapguide
tmerz trishmerz at gmail.com
Fri Jan 30 16:22:44 EST 2009
Hi there,
I've found many of the posting regarding connecting PostGIS and MGOS
extremely useful.  I have managed to create a datasource, point it to the
PostGIS database, and no errors are reported when testing the connection.
GREAT!
However...  Now, I am trying to create a map that will allow me to display
my postGIS data.  I have created a new layer in MGOS Web Studio and pointed
the layer to my postGIS datasource (as suggested in step 5-6).
At this point, "Step 7 Select the table to use", I am not able to select any
tables.  I am attempting to select a feature source from the drop down list,
but it is empty.  Should my PostGIS tables show up at this point?
Any feedback regarding displaying PostGIS data after establishing a
connection would be greatly appreciated!
TMerz
> 1. Create a datasource
How does one create a datasource using WebStudio or can some please post a
working example of a datasource.
On 13/09/2007, Kenneth, GEOGRAF A/S <ks at geograf.dk> wrote:
>  If you are able to connect to the datasource, there should be no problem
> displaying it.
> These are the steps to follow:
> 2. Point it to the PostGIS database
> 3. Click "Test connection"
> 4. When it works, save the datasource.
> 5. Create a new layer
> 6. Point the layer to the datasource.
> 7. Select the table to use.
> 8. Style the point, line and area to your pleasing.
> 9. Save the layer.
> 10. Create a mapdefinition.
> 11. Select the correct projection for the data.
> 12. Add the layer to the map, make sure you have "Layer is initially
> visble in the map" checked.
> 13. Save the map.
> 14. Create a new WebLayout.
> 15. Select the map.
> 16. Save the WebLayout.
> After item 7, you should be able to preview your data, using the "Preview"
> feature.
> Item 8 is where you could set up filters and the like.
> You can repeat item 12, if you have many layers.
> If the above does not help, try to explain where it goes wrong.
> Regards, Kenneth, GEOGRAF A/S
View this message in context: http://n2.nabble.com/Postgis-mapguide-tp1812261p2247155.html
