[mapguide-users] SQL 2008, MGOS 2.0.2, FDO 3.3.x - 3.4.x, Maestro
1.0.9 do not cooperate
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Sat Jan 31 11:42:36 EST 2009
Studio does not yet support the MSSQL server provider directly, so you
will get a "generic page", which is not likely to solve your problem.
Instead, try looking at the error log:
C:\Program Files\MapGuideOpenSource2.0\Server\Logs\Error.log
It usually explains what the problem is.
Another method is to use the WebAPI test form:
http://localhost/mapguide/mapagent/index.html
Especially the call to "DescribeFeature" should be interresting in the
case where Maestro reports an invalid
document. If you get a document that looks valid, but Maestro rejects
it, please create a bug ticket for that,
and attach the xml document:
http://trac.osgeo.org/mapguide/newticket
(You will need an OSGeo ID).
Regards, Kenneth Skovhede, GEOGRAF A/S
miansi skrev:
> Hello,
> I am newbe in this area and I am trying to marry SQL 2008 with MGOS.
> I used this topic to do transfer from SHP to SQL
> http://www.longhorncorner.com/UploadFile/nschan/Shapefiles04112007005648AM/Shapefiles.aspx
> Last Friday everything was fine and I was able to see my data on the map.
> Then something happens :-) and I wasn't able to see data from SQL on the map
> anymore.
> To eliminate environment-related issues I started from scratch and installed
> new MGOS 2.0.2 server and the story begins...
> The way I was changing FDO was stop MapGuide Server service, delete
> everything from C:\Program Files\MapGuideOpenSource2.0\Server\Bin\FDO and
> replace it with files from fdosdk-win32-3.3.1\Bin or fdosdk-win32-3.3.2\Bin
> and so on. So I was using Windows SDK files.
> Using FDO 3.4.0.Beta1 through FDO 3.3.2 allows me to create DataSource,
> which points to my SQL Server database, but gives me "Failed to read schema
> from data source. The operation gave the error message: Bad document" when I
> am trying to choose Feature Source while creating layer in MapGuide Maestro
> (both v1.0.9 and r3558). Out of the box.
> Using FDO 3.3.1 allows me to create DataSource and Layer, but shows no data
> on the map even though I know that there is data in the table and I can see
> it on the Spatial Results tab in the SQL. I check that my Initial Map View
> set to the right values.
> Next step for me would be to try installing Autodesk MapGuide Studio trial
> and using FDO SQL 2008 spatial provider from there...
> But before I would do so I have a question.
> Is there checklist of components/requirements defined and tested for MGOS
> <-> SQL 2008 integration?
> Like
> 1. PK in the table has to be int/bigint/...
> 2. Geometry column has to have a clustered index
> 3. FDO has to be version ...
> 4. Maestro ...
> Any help would be greatly appreciated.
> Thank you!
