[mapguide-users] Postgis/mapguide
Zac Spitzer zac.spitzer at gmail.com
Fri Jan 30 19:38:51 EST 2009
Try using Maestro or MapGuide Studio, Web studio is more a proof of concept
and has issues.... probably should be removed from the distribution IHMO
z
On Sat, Jan 31, 2009 at 8:22 AM, tmerz <trishmerz at gmail.com> wrote:
> Hi there,
> I've found many of the posting regarding connecting PostGIS and MGOS
> extremely useful.  I have managed to create a datasource, point it to the
> PostGIS database, and no errors are reported when testing the connection.
> GREAT!
> However...  Now, I am trying to create a map that will allow me to display
> my postGIS data.  I have created a new layer in MGOS Web Studio and pointed
> the layer to my postGIS datasource (as suggested in step 5-6).
> At this point, "Step 7 Select the table to use", I am not able to select any
> tables.  I am attempting to select a feature source from the drop down list,
> but it is empty.  Should my PostGIS tables show up at this point?
> Any feedback regarding displaying PostGIS data after establishing a
> connection would be greatly appreciated!
> TMerz
>> 1. Create a datasource
> How does one create a datasource using WebStudio or can some please post a
> working example of a datasource.
> On 13/09/2007, Kenneth, GEOGRAF A/S <ks at geograf.dk> wrote:
>>  If you are able to connect to the datasource, there should be no problem
>> displaying it.
>> These are the steps to follow:
>> 2. Point it to the PostGIS database
>> 3. Click "Test connection"
>> 4. When it works, save the datasource.
>> 5. Create a new layer
>> 6. Point the layer to the datasource.
>> 7. Select the table to use.
>> 8. Style the point, line and area to your pleasing.
>> 9. Save the layer.
>> 10. Create a mapdefinition.
>> 11. Select the correct projection for the data.
>> 12. Add the layer to the map, make sure you have "Layer is initially
>> visble in the map" checked.
>> 13. Save the map.
>> 14. Create a new WebLayout.
>> 15. Select the map.
>> 16. Save the WebLayout.
>> After item 7, you should be able to preview your data, using the "Preview"
>> feature.
>> Item 8 is where you could set up filters and the like.
>> You can repeat item 12, if you have many layers.
>> If the above does not help, try to explain where it goes wrong.
>> Regards, Kenneth, GEOGRAF A/S
> View this message in context: http://n2.nabble.com/Postgis-mapguide-tp1812261p2247155.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer -
http://zacster.blogspot.com
+61 405 847 168
