[mapguide-users] Error on services (mgserver.exe)
Dave Wilson
dave.wilson at autodesk.com
Fri Jun 12 10:27:12 EDT 2009
The most common reason for this kind of error is usually a bad path to one of the directories outlined in Site Admin. If for example you changed the location of the repository and the system can't find the files you will see this behavior.
Edit your serverconfig.ini (in Notepad only) and check your paths.
Regards,
Dave
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Kenneth Skovhede, GEOGRAF A/S
Sent: Friday, June 12, 2009 7:01 AM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] Error on services (mgserver.exe)
Ocasionally there is also information in the System event log (not the performance log).
Start -> Control Panel -> Administrative Tools -> Eventlog
Click on "Applications".
As a last resort, try running mgserver.exe in interactive mode as explained on the bottom of this page:
http://trac.osgeo.org/fdo/wiki/FdoGdalNotes
Regards, Kenneth Skovhede, GEOGRAF A/S
Zac Spitzer skrev:
under server\logs in the installation dir
On Fri, Jun 12, 2009 at 2:11 PM, ajid<ah_jid at yahoo.com><mailto:ah_jid at yahoo.com> wrote:
i donno where d log location.. it nothin on that performance alert.
see d image http://n2.nabble.com/file/n3065927/error2.jpg
http://n2.nabble.com/file/u115131/avatar_1500.gif
View this message in context: http://n2.nabble.com/Error-on-services-%28mgserver.exe%29-tp3065836p3065927.html
mapguide-users mailing list
mapguide-users at lists.osgeo.org<mailto:mapguide-users at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090612/3810c2bf/attachment.html
