[mapguide-users] Load AutoCAD Map 3D DWG file
Jackie Ng jumpinjackie at gmail.com
Tue Mar 10 04:00:41 EDT 2009
I don't think Studio can load dwgs made with AutoCAD vertical products (eg.
Map 3D), it will just treat them as vanilla AutoCAD dwgs. I could be wrong
here.
- Jackie
mkaram84 wrote:
> Hi
> We have an AutoCAD Map 3D DWG file which its layers have blocks. The
> blocks are linked to an Oracle Database 10g R2 by two link templates:
> "MG_ID" and "MG_Name".
> When we try to load the DWG file into Mapguide Enterprise 2009 through
> Autodesk MapGuide Studio 2009, the loading is done successfully with one
> problem that I can't see the link templates in the Feature Data.
> I tried to publish the DWG to MapGuide Enterprise 2009 from AutoCAD Map 3D
> 2009, and it has the same effect that i can't see the link templates in
> the Feature Data.
> I tried to export the Layers to SDF from Map 3D 2006 and I can
> successfully export to SDF with the two link templates, but when I tried
> to load this SDF into Studio 2009 it doesn't load any symbols or blocks
> (just a Point Layer)
> My problem here: I need to load the DWG Layers with its two link templates
> and also the symbols (blocks) into MapGuide Studio 2009.
> Your help will be appreciated
> Thanks & Regards
View this message in context: http://n2.nabble.com/Load-AutoCAD-Map-3D-DWG-file-tp2453726p2453758.html
