[mapguide-users] Need help to set up raster
Dju djutopie at hotmail.com
Wed May 6 16:23:58 EDT 2009
I'm not a specialist but in Maestro i choose the coordinate system
that match best with mine : select (in coordinate system) EPSG,
my coordinate system and then Maestro will write the WKT code.
You just have to edit the parameters you want to change and validate.
Try  http://spatialreference.org/ref/epsg/ this  if you don't find your
coordinate system
and type directly the EPSG code in Maestro.
View this message in context: http://n2.nabble.com/Need-help-to-set-up-raster-tp2820261p2824175.html
