[mapguide-users] Creating a temporary feature source that is not an SDF file
adnanc adnan.chughtai at keynetix.com
Fri May 8 05:51:00 EDT 2009
Thankyou Jackie for explaining the solution so well.
Just tried it and it worked fine.
Regards,
Adnan
Jackie Ng wrote:
> If you understand that feature sources are just xml documents that
> describe a FDO connection to a particular data store, then
> CreateFeatureSource()/MgCreateSdfParams is just a convenience method that
> does the following:
> 1) Create the SDF file, with the specified schema
> 2) Create an XML feature source document for this created SDF
> 3) Sets the resource content (feature source) based on the given resource
> id
> 4) Uploads the created SDF file as the resource data for the given
> resource id
> What is so special about MgCreateSdfParams is that it can create the SDF
> data store for you (the 1st part). For anything other than SDF, this data
> store creation ability is not exposed and you will need to have the data
> on hand already or use the FDO API to create the data store.
> However you can achieve the same effect (parts 2, 3 and 4) using
> SetResource() and SetResourceData() methods of MgResourceService.
> I think in your case, what you want to do is to copy the raster feature
> source to your session repository, and modify its configuration document.
> No CreateFeatureSource() call is required.
> Hope that helps.
> - Jackie
> adnanc wrote:
>> Hello all,
>> I am currently serving georeferenced tiffs with the GDAL provider, using
>> a config file for indexing them.
>> A requirement I have is to enable a user to select an area of interest
>> and be able to programmatically generate the config file of tiffs for
>> that particular area.  I have been able to complete this functionality
>> using the gdal api.
>> The next step is to create a session based layer for displaying these
>> tiffs, however this also needs a session based feature source.  I have
>> created a session based feature source but it is an SDF feature source.
>> Doing the following will add the config file to the feature source, but
>> it will not display any tiffs.
>> resourceService.SetResourceData(resID, "ConfigurationDocument", "Stream",
>> byteReader);
>> The MgFeatureSourceParams class only has one concrete class
>> MgCreateSdfParams.
>> Has any one had a similar requirement or know of a workround for the
>> above problem.
>> Thanks for your time,
>> Adnan
View this message in context: http://n2.nabble.com/Creating-a-temporary-feature-source-that-is-not-an-SDF-file-tp2828125p2844460.html
