[mapguide-users] Bookmarking Revisited - LINKTOVIEW
GordonL gordon.luckett at arrowgeomatics.com
Wed Oct 7 18:07:05 EDT 2009
Hi Jason, I have figured it out.  If you add the LinkToView widget, you must
add it in the "Staus Bar"
Once there, it becomes a hyperlink that stores the current extents of the
map and application definition:
http://localhost/mapguide/fusion/templates/mapguide/slate/index.html?applicationdefinition=Library://REDDING/7_FLEXIBLE_LAYOUTS/test.ApplicationDefinition&$family=[object
Object]&extent=1900945.541449,451170.619684,1908778.640057,456877.05094
I am not sure what $family is...
Unfortunately it does not remember Layer on/off status and you would have to
figure out how to capture this URL and pass it to one's application.
The NanaimoMap is a much cleaner method, but customized FUSION.js on your
site though....
thanks
gordon
Jason Birch wrote:
> Latest fusion 1.1 from branch. You can find my
> ApplicationDefinition.xml in the nanaimomap folder. Everything else
> should be in the html and nanaimo.js (or something like that). Be
> aware that some extensions (redlining at least) are proprietary.
> On 2009-10-07, GordonL <gordon.luckett at arrowgeomatics.com> wrote:
>> Thanks Jason,
>> I just saw this on your site.  What version are you using? Fusion from
>> 2.0.2?
>> I did not see it defined, is it define in your applicationdefinition?
>> gordon
>> Jason Birch wrote:
>>> Gordon, I believe that NanaimoMap does this (though the layer state
>>> doesn't
>>> appear to be working currently; hmm).
>>> I'm not 100% sure how it works though, so you'd have to reverse engineer
>>> it
>>> or hope that Mike or Paul steps in here :)
>>> Jason
>>> 2009/10/5 GordonL <gordon.luckett at arrowgeomatics.com>
>>>> Hi All,
>>>> I was wondering if anyone has ever tried the LINKTOVIEW widget in
>>>> Fusion?
>>>> If so, how did you get it to work?
>>>> example? version?  MGOS 2.0.2 or beta etc?
>>>> thanks!
>>>> gordon
>>>> View this message in context:
>>>> http://n2.nabble.com/Bookmarking-Revisited-LINKTOVIEW-tp3771957p3771957.html
>>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>>> _______________________________________________
>>>> mapguide-users mailing list
>>>> mapguide-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> http://n2.nabble.com/Bookmarking-Revisited-LINKTOVIEW-tp3771957p3784443.html
View this message in context: http://n2.nabble.com/Bookmarking-Revisited-LINKTOVIEW-tp3771957p3784749.html
