[mapguide-users] Re: Mapguide Open Source 2.1 2811 Port issue
Jackie Ng jumpinjackie at gmail.com
Mon Aug 30 20:44:01 EDT 2010
You could edit the serverconfig.ini and webconfig.ini files and change the
port numbers to something that is not already taken. By default MapGuide
uses port numbers 2810, 2811, 2812.
Of course this should only be a last resort should you fail to find what
application is already using port 2811.
- Jackie
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Mapguide-Open-Source-2-1-2811-Port-issue-tp5480530p5480760.html
