[mapguide-users] mrsid
Andrew DeMerchant
andrew.demerchant at gemtec.ca
Mon Aug 30 21:34:41 EDT 2010
I don't know anything much about the gdal or mapguide x64, but I do
know that that sort of message is typically related to a conflict
between x64 and x86 (ie, mixing versions). I'd be willing to bet that
the gdal dlls are x86 and don't play with the x64 mapguide install.
Again - I don't know much about this stuff, but I've seen this before
with other software that just started to support x64.
Andrew
On 30/08/2010 10:24 PM, jtby wrote:
> trying to get mrsid rasters working in mapguide on windows server 2008 64 bit
> (installed from MapGuideOpenSource-2.2.0.4982-Beta1-x64). I believe I have
> placed the various DLLs in correct locations per the docs. However running
> mgserver interactive at command line and then adding sid in maestro I see:
> Error 1: Can't load requested DLL: c:\program
> files\osgeo\mapguide\server\bin\gdalplugins\gdal_ECW_JP2ECW
> 193: %1 is not a valid win32 application
> ... same with gdal_mrsid.dll
> ... any ideas?
This e-mail message (including attachments, if any) is confidential and may be privileged. Any unauthorized distribution or disclosure is prohibited. Disclosure to anyone other than the intended recipient does not constitute waiver of privilege. If you have received this e-mail in error, please notify us and delete it and any attachments from your computer system and records.
Ce courriel (y compris les pièces jointes) est confidentiel et peut être privilégié. La distribution ou la divulgation non autorisée de ce courriel est interdite. Sa divulgation à toute personne autre que son destinataire ne constitue pas une renonciation de privilège. Si vous avez reçu ce courriel par erreur, veuillez nous aviser et éliminer ce courriel, ainsi que les pièces jointes, de votre système informatique et de vos dossiers.
