[mapguide-users] Installation error
spatialminds craig.miller at spatialminds.com
Tue Jan 12 20:42:25 EST 2010
Thanks for the help.  I didn't realize host headers weren't allowed and this
website use them quite a bit.
Will a manual install allow me to get it working on this server?  I didn't
see any links in any of the quoted emails that detailed how to do a manual
install.
Thanks for the help on this.
Craig
On Tue, Jan 12, 2010 at 2:43 PM, Jason Birch [via OSGeo.org] <
ml-node+4295033-54498305 at n2.nabble.com<ml-node%2B4295033-54498305 at n2.nabble.com>
> wrote:
> The error message in the log indicates the same kind of problem...
> ConfigureIIsExec:  Skipping ScaInstallWebDirs() because IIsWebDir
> table not present
> Google turns up a few hits on this all pointing in the same direction.
> So, to confirm, your default web site is named "Default Web Site", and
> is set to all unassigned IP addresses, no host header, port 80?  I
> earlier thought that only the name had to match, but some of the
> earlier comments in this thread make it clear that all of the
> parameters may have to match what's defined here:
> http://trac.osgeo.org/mapguide/browser/branches/2.1/Installer/Libraries/MapGuide%20Web%20Extensions/IIS.wxs#L17
> If that's the case, the only thing I can recommend is, as above,
> choosing the manual option and then manually configuring IIS.  The
> link above has all the steps in it, but is a bit cryptic :)  I've been
> meaning to document this (there are some "Configuring MapGuide on
> Windows" documents floating around for earlier versions of MGOS) but
> haven't found the time yet.
> Jason
> 2010/1/11 spatialminds
> > Jason,
> > Thank you for providing an in-depth reply to the original posters
> question.
> > I am having an identical problem as the original poster on a Windows 2003
> > SP2 server install I'm doing.  Same setup (MG 2.1.0, Windows Server 2003,
> > .NET dev setup, installing to IIS 6).  I have been told that the Default
> > Website has never been renamed or deleted.  The server I am installing to
> > has a few remnants of Microsoft Small Business Server on it, which
> > originally came with sharepoint, outlook web access, etc but these were
> long
> > ago removed removed.
> > I've created an install log and placed it at http://tinyurl.com/msilog
> > Thanks for any help you can lend,
> > Craig
> mapguide-users mailing list
> [hidden email]<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=4295033&i=0>
>  View message @
> http://n2.nabble.com/Installation-error-tp3858392p4295033.html
> To unsubscribe from Re: Installation error, click here< (link removed) >.
Craig Miller
Geospatial Software Architect
View this message in context: http://n2.nabble.com/Installation-error-tp3858392p4295796.html
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20100112/99f7fb3f/attachment.html
