[mapguide-users] Problem with map only half showing.
Dave Wilson dave.wilson at autodesk.com
Thu Jan 28 13:00:04 EST 2010
Does the GDAL provider use a config.xml which contains the file details and bounds similar to the Autodesk provider? It sounds like a problem reading the config.xml
Dave
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of JamesDudden
Sent: Thursday, January 28, 2010 8:39 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Problem with map only half showing.
I sometimes have a problem where the map (OS raster tiff files) doesn't
fully show. This is often resolved by panning around or zooming in and out
until the map 'sorts itself out'.
The most frequent occurence of this is when I use an invoke script to hide
the layer and taskbar panels (so to leave one big map). The panels move and
the map disappears - sometimes completely!
The error in the log is as follows:
<2010-01-28T11:09:07> 		127.0.0.1	Administrator
 Error: Failed to stylize layer: All OS
        An unclassified exception occurred.
 StackTrace:
  - MgMappingUtil.StylizeLayers line 786 file
d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\mapping\MappingUtil.cpp
Has anybody else experienced raster layers only partialy showing?
Is there an explanation or even a fix?
Any help or advice is welcome
Regards
JD
http://www.software-matters.co.uk Software Matters  -
http://www.software-matters.co.uk/bespoke-database-design.html Bespoke
Database  and Software Solutions
View this message in context: http://n2.nabble.com/Problem-with-map-only-half-showing-tp4473961p4473961.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
