[mapguide-users] RE: DWF's display poorly
Plantech jerryr at plan-tech.com
Wed Jul 21 15:51:04 EDT 2010
What plotter configuration are you using to create the DWF?  I use the "DWF6
ePlot DETE.pc3" which generally produces good results for us.  I believe it
is also the one used "automatically" by the "Publish to Mapguide" function
within Autocad Map 3D.  It plots to fit paper size 100 x 100 inches and uses
a vector resolution of 1200 dpi.
The only problem we ocassionally have is a font not being rotated properly.
It rotates and looks ok when viewed with Autodesk Design Review but in
Mapguide Enterprise when uploaded as a data source and layer, some text
rotates properly and some doesn't. ???
View this message in context: http://osgeo-org.1803224.n2.nabble.com/DWF-s-display-poorly-tp5321851p5322647.html
