[mapguide-users] Tool tip issue
LLEUNDD
nuell at nicholsenvironmental.com
Mon Jun 7 14:44:13 EDT 2010
Hi Listers -
I have two applications as follows:
Application 1 - a weblayout with no commercial map service where a certain
group of points have tool tips. When I load the fusion layout through MG
studio (view in browser), the tool tips work perfectly.
Application 2 - a weblayout with commercial map service that I access
through http://abc.com/mapguide/fusion/templates/maguide/client/index.html
and the tool tips don't show.
In MG Studio, the same point layer is used for both weblayouts - so there is
nothing different there.
I suspect that I need to add something to the applicationdefinition.xml of
the template to read tooltips or other widgets? Perhaps I am way off base
on this and I need to look elsewhere.
Can anyone lead me in the correct direction...
Thanks.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Tool-tip-issue-tp5150518p5150518.html
