[mapguide-users] Re: [mapguide-internals] Fwd: [mapguide-announce]
MapGuide Open Source 2.2 beta released
Jason Birch
jason at jasonbirch.com
Tue Jun 8 02:47:49 EDT 2010
Zac, are there any other services running under the same userid as
MapGuide? Not requiring the cs-map env var means that either
something has changed with how Windows loads the profile for the
services, or that userid hadn't been logged in as a service yet.
On 2010-06-07, Zac Spitzer <zac.spitzer at gmail.com> wrote:
> Just installed on my new windows 7 64-bit machine (bundled apache
> config with php)
> and it all works fine... dind't even need to reboot, just had to
> manually start the
> apache service.... very zippy indeed
> anyone trying this who wants to use studio, should follow this tip
> to set the 32 bit flag for studio....
> http://mapguide.wordpress.com/2009/12/15/mapguide-studio-2010-with-64-bit/
> z
> On 4 June 2010 13:14, Jackie Ng <jumpinjackie at gmail.com> wrote:
>> Could you create a trac ticket with an attached MSI log of the failed
>> installation?
>> To enable MSI logging run the internal msi as so:
>> msiexec /l*v install.log /i <name of the msi>
>> The exe installer is just a self-extracting executable. You should be able
>> to extract the internal msi using 7-zip (http://7-zip.org)
>> - Jackie
>> View this message in context:
>> http://osgeo-org.1803224.n2.nabble.com/MapGuide-Open-Source-2-2-beta-released-tp5126722p5137912.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> Zac Spitzer
> Solution Architect / Director
> Ennoble Consultancy Australia
> http://www.ennoble.com.au
> http://zacster.blogspot.com
> +61 405 847 168
