[mapguide-users] Re: How to rotate the map??
Zac Spitzer zac.spitzer at gmail.com
Tue Jun 22 07:28:33 EDT 2010
Tricks from down under hehe
On 22 Jun 2010 21:05, "Jackie Ng" <jumpinjackie at gmail.com> wrote:
> There is no API or functionality to rotate a given map.
> However I've learned of a clever "hack" from a client which involves
> assigning a custom "south oriented" projection for the map which is the
> opposite of the current projection. Mapguide's on the fly reprojection
will
> then "rotate" the map for you.
> Unfortunately my knowledge of wkt syntax is weak. So I can't exactly say I
> can tell you how to create this custom projection
> - Jackie
http://osgeo-org.1803224.n2.nabble.com/How-to-rotate-the-map-tp5207976p5208256.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20100622/e9b85e09/attachment.html
