[mapguide-users] Re: How to rotate the map??
GordonL
gordon.luckett at arrowgeomatics.com
Tue Jun 22 09:22:03 EDT 2010
Hi, about 12 years or so ago, I came up with a trick for the old MapGuide..I
would create a coordinate system using the Oblique Sterographic with
OSTEROUS coordinates with WGS84.
"Gord's Coords" they called it.
You can set the parameters such as:
<Projection Code="OSTEROUS">
<LatitudeOfOrigin>49.2124055555556</LatitudeOfOrigin>
<LongitudeOfOrigin>-122.917591666667</LongitudeOfOrigin>
<FalseEasting>506001.915</FalseEasting>
<FalseNorthing>5451071.504</FalseNorthing>
<MapScale>1</MapScale>
<ScaleReductionFactor>1</ScaleReductionFactor>
<CombinedScaleFactor>1</CombinedScaleFactor>
<UnitsCode>METER</UnitsCode>
<UnitsScaleFactor>1</UnitsScaleFactor>
<P1>-39.5</P1>
The most important part was the P1 parameter (or rotation).
I used this technique for printing with the Dynamic Authoring Toolkit. I
have defined this in Autodesk Map 3D and ported the CSD files over to
MapGuide in the past, but I would love to the PROJ WKT definition for this
if anyone has it...
View this message in context: http://osgeo-org.1803224.n2.nabble.com/How-to-rotate-the-map-tp5207976p5208726.html
