[mapguide-users] Re: How to rotate the map??
Bob Basques Bob.Basques at ci.stpaul.mn.us
Tue Jun 22 11:14:58 EDT 2010
Gordon,
Do you have any sample output for this projection "trick"?  It sounds like something I've been after for a few years now, and for the same use as you, with PROJ.
bobb
>>> GordonL <gordon.luckett at arrowgeomatics.com> wrote:
Hi, about 12 years or so ago, I came up with a trick for the old MapGuide..I
would create a coordinate system using the Oblique Sterographic with
OSTEROUS coordinates with WGS84.
"Gord's Coords" they called it.
You can set the parameters such as:
      <Projection Code="OSTEROUS">
        <LatitudeOfOrigin>49.2124055555556</LatitudeOfOrigin>
        <LongitudeOfOrigin>-122.917591666667</LongitudeOfOrigin>
        <FalseEasting>506001.915</FalseEasting>
        <FalseNorthing>5451071.504</FalseNorthing>
        <MapScale>1</MapScale>
        <ScaleReductionFactor>1</ScaleReductionFactor>
        <CombinedScaleFactor>1</CombinedScaleFactor>
        <UnitsCode>METER</UnitsCode>
        <UnitsScaleFactor>1</UnitsScaleFactor>
        <P1>-39.5</P1>
The most important part was the P1 parameter (or rotation).
I used this technique for printing with the Dynamic Authoring Toolkit.  I
have defined this in Autodesk Map 3D and ported the CSD files over to
MapGuide in the past, but I would love to the PROJ WKT definition for this
if anyone has it...
View this message in context: http://osgeo-org.1803224.n2.nabble.com/How-to-rotate-the-map-tp5207976p5208726.html
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20100622/2d73a876/attachment.html
