[mapguide-users] Re: Images into custom symbols
Jason Birch jason at jasonbirch.com
Wed Jun 23 01:54:52 EDT 2010
I'm pretty sure that it doesn't support emf files. Would have been
nice, all of my MG 6.5 symbols were in that format. I ended up
creating all my utility symbols from scratch using graph paper and
calculator (lots of sohcahtoa @ arc calculations) though you might
have better luck with something that exports to a similar format. I
tried using inkscape(?) But it wasn't exact enough for my needs.  I'm
willing to share these BTW; just haven't had time to document them
properly.
All you should have to do is upload an image to the resource data
section at the bottom of the symbol XML editor in in recent Maestro
releases, and change your reference to the name of that image. If that
doesn't work, the format probably isn't supported.
Jason
On 2010-06-22, Steve G <steve.golden at morganhill.ca.gov> wrote:
> My reference to MapGuide Studio was the only thing that I could find
> regarding what type of image file formats may be supported other than png.
> I dabbled with Studio a while back and tested creating symbols and based on
> some old symbol library resource that is still on my test server I think you
> are right Jason, it did convert to dwf.  So perhaps those file formats are
> really not supported in MapGuide, just formats that Studio is able to
> convert from.  I am using Maestro now, so whatever Studio supports is not
> available to me.
> I did see that wiki page, but perhaps I do not understand enough about the
> SymbolDefinition schema to properly reference the image file (non-PNG image
> file).  Like I said, if I change the file name to XXX.emf and upload the emf
> file, the images do not appear as symbols for the layer.
> Any thoughts or sample SymbolDefinition files that I could try?  Thanks.
> -Steve
> http://osgeo-org.1803224.n2.nabble.com/Images-into-custom-symbols-tp1818670p5211846.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
