[mapguide-users] Re: Again: strong naming of MapGuideDotNetApi.dll
Gunter Becker
gunter.becker at csogis.de
Fri Oct 15 07:50:28 EDT 2010
OK, I'm back trying to get MaestroAPI work with MGOS2.2 ddl's.
I have decompiled the dll's, edited the il-files and compiled them with the
maestrokey. Then I tried using the strong signed dll's in a basic
webapplication: just trying to get a connection to MapGuide without the
MaestroAPI.
Know I got the following error:
Could not load file or assembly 'OSGeo.MapGuide.Foundation, Version=1.0.0.1,
Culture=neutral, PublicKeyToken=null' or one of its dependencies.
A strongly-named assembly is required. (Exception from HRESULT:
0x80131044)":"OSGeo.MapGuide.Foundation, Version=1.0.0.1, Culture=neutral,
PublicKeyToken=null"
I thought I've done something wrong in the process of strong naming the
dll's. So I double-checked the procedure. I also looked at the files with
.NET Reflector: the dll itself and all their references to
OSGeo.MapGuide.*.dll have PublicKeyToken=f526c48929fda856.
So I'm absolutely sure that they are correct
In my tests I also tried to change the version (see my previous post) and
replaced all the strings "1.0.0.1" to "2.2.0.0". Compilation seems to work.
Now the error looks like that:
Could not load file or assembly 'OSGeo.MapGuide.Foundation, Version=2.2.0.0,
0x80131044)":"OSGeo.MapGuide.Foundation, Version=2.2.0.0, Culture=neutral,
The version has changed in error message but not the PublicKeyToken.
So, is there maybe another place where we have to change the key or do we
missing anything else?
Gunter
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Again-strong-naming-of-MapGuideDotNetApi-dll-tp5622823p5638613.html
