[mapguide-users] Re: Selection and Tooltips for Symbols in Fusion
vs. Ajax
Jackie Ng
jumpinjackie at gmail.com
Sun Apr 17 21:26:39 EDT 2011
If it is the case that the layers are being re-projected then your tolerance
values may need adjustment, since you are now working in Popular
Visualisation Mercator instead of WGS84.
On a side note: Are you registered on the mailing list? Nabble is flagging
your posts as not being accepted.
- Jackie
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Selection-and-Tooltips-for-Symbols-in-Fusion-vs-Ajax-tp6280386p6282211.html
