[mapguide-users] Is GDAL working and Stable in 2.2?
Trevor Wekel trevor_wekel at otxsystems.com
Thu Aug 18 17:02:25 EDT 2011
Hi Mike,
I have successfully performed lightweight load testing on the 64 bit Windows build with some ECW, MrSID, and TIFF data using the information contained at http://trac.osgeo.org/mapguide/wiki/MGOS22GdalProvider.  So yes, for my data set I would say that it is stable.
There are a few limitations which may impact your implementation:
Occasionally MapGuide does not correctly return the extents or coordinate system of the raster data.  This makes authoring more difficult.  Jackie has a patch to improve this behaviour attached to http://trac.osgeo.org/mapguide/ticket/740.
The FDO GDAL Provider has only been tested with a single connection.
[FeatureServiceProperties]
DataConnectionPoolSizeCustom = OSGeo.Gdal:1
Enabling multiple connections may cause raster to go unstable.  This means that MapGuide and FDO GDAL will only process one raster data set concurrently.  If you have a lot of users and a lot different raster data sets, this could be a significant bottleneck.
I would like to take another pass at MapGuide & FDO GDAL for the 2.4 release.  There is some interest in adding configurable resampling (bilinear, cubic, etc) and we really do need to remove the single connection limitation.  I can make time available to do this work if funding is available.  This would move MapGuide + FDO GDAL Provider closer to parity with MapGuide + Autodesk Raster Provider.
Regards,
Trevor
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Mike Micallef
Sent: August 18, 2011 2:20 PM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Is GDAL working and Stable in 2.2?
Not complaining - just discouraged...
Is GDAL working and stable in 2.2 - all kinds of different and older posts
out there about partial work-arounds, Trevor’s investigation, locking it up,
this is the problem, that’s the problem...
We use imagery and it has been a struggle migrating through the releases and
trying out the fixes - I do not want to move until I am sure how to handle
the imagery.
We have custom code all over the place and to migrate is a bit of an
undertaking....
m
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Is-GDAL-working-and-Stable-in-2-2-tp6700721p6700721.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
