[mapguide-users] MGE performance. It's soooooo Slllllllooooooowwww
Martin Morrison martin.morrison at edsi.com
Fri Jan 28 15:06:06 EST 2011
The trick is multiple layers.  One layer zoomed out that has been generalized, then zoom in to a more accurate layer.
Martin Morrison
Application Engineer
Engineering Design Systems, Inc.
3780 Peters Creek Rd Ext SW
Roanoke, VA  24018
540.345.1410
gis.edsi.com
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Warren Medernach
Sent: Friday, January 28, 2011 3:04 PM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] MGE performance. It's soooooo Slllllllooooooowwww
Something else I've found is that you just cannot show as much data in the initial view in MGE like you could in MG6.x.  I've seen many MG6.x sites that had dozens of layers turned on in the initial view that just made no sense to be on at that view scale.  But... the old technology handled it fine, so people expect the new technology to behave exactly like the old one.
I guess what I'm trying to say is, you need to be much more 'prudent' with your display ranges, and what layers really need to be turned on, in MGE to get decent performance.
Warren
On Fri, Jan 28, 2011 at 1:49 PM, Martin Morrison <martin.morrison at edsi.com<mailto:martin.morrison at edsi.com>> wrote:
I agree on using the AJAX viewer.  Put the data in SQL server, index the geom, use AJAX and fly...if you need help, let me know.
Martin Morrison
Roanoke, VA  24018
540.345.1410
gis.edsi.com<http://gis.edsi.com>
From: mapguide-users-bounces at lists.osgeo.org<mailto:mapguide-users-bounces at lists.osgeo.org> [mailto:mapguide-users-bounces at lists.osgeo.org<mailto:mapguide-users-bounces at lists.osgeo.org>] On Behalf Of Andrew DeMerchant
Sent: Friday, January 28, 2011 1:58 PM
What, specifically, can't you do with the AJAX viewer? I've certainly noticed the serious performance slowdown with Fusion (vs AJAX), which is why I'm still using the AJAX viewer, myself. My suggestion would be to try to figure out if you really can't do what you'd like with the AJAX viewer (if it's fast enough for you, I mean).
Andrew
On 11/01/28 2:05 PM, frosty1_4me wrote:
We have been working on a complete migration from 6.5 to MGE as a pilot to
see if we can actually move to the new platform since the 6.5 software is no
longer supported.
We have brought across everything from our 6.5 app to the new MGE framework
(using fusion due to the required functionality), we have also made alot of
changes in an attempt to speed up our data.  We currently use SQL for our
db's, but we've went so far as to setup static tables instead of news in the
db, we have also imported data and stored in directly in the SDF's to try
and speed things up, but nothing we have tried really makes a difference.
The performance of MGE using Fusion is unbelievabley slow and there doesn't
seem to be anything we can do.
Take for example a simple SDF3 of parcels.  We created an SDF3 that has
about 23k parcels and instead of linking it to a db, we attached the data to
the parcels in an attempt to speed up the flyouts in MGE.  The data is only
a simple ID, and another db field for testing purposes.  We used the tooltip
method in MGE and we also tried using an aspx page to load the simple
dataset instead of the tooltip directly accessing the data from the
attribute list in MGE.   The results were the same, slow flyout loading
times.  To make things worse, if we turned on a layer which has alot of
data, then tested the flyouts again for the parcels, it takes about 15secs
for the flyout to appear.  Obviously thats not acceptable.
I don't know what else we can do with all of this.  The performance of MGE
is absolutely horrible, and after using 6.5 for so long we actually are
considering going to a completely different GIS software. (Esri?)
How are others dealign with this performance issue?  The basic AJAX viewer
is faster, but you also don't have the tools and flexablitly that you do
with the Fusion setup.
Thanks.
[?ui=2&ik=12e68cc8cc&view=att&th=12dce2c4a9de0031&attid=0.0.1&disp=emb&zw]<http://www.gemtec.ca/>
Andrew DeMerchant
tel: 506.453.1025  /  toll-free: 1.877.243.6832
fax: 506.453.9470
mapguide-users mailing list
mapguide-users at lists.osgeo.org<mailto:mapguide-users at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20110128/205362c3/attachment.html
