[mapguide-users] SV: zoom to extent using bookmarks
Zac Spitzer zac.spitzer at gmail.com
Thu Oct 27 03:58:39 EDT 2011
fusion uses openlayers, so you can use the openlayers api
there are examples over in the fusion mailing list archives
you might find this a useful starting point
http://mapguide-central.ennoble.com.au/
On Thu, Oct 27, 2011 at 6:45 PM, Von Barth, Peter <Peter.vonBarth at eon.se> wrote:
> Hi!
> Just to clarify.
> I want to zoom to a given extent within a fusion application.
> In the ajaxviewer I can call the ZoomToExtent API function through an invoke
> script.
> But how do I do this from a fusion application? Do I have to create a new
> widget or is there a function or script I can use within fusion?
> /Peter
> Från: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] För Von Barth, Peter
> Skickat: den 26 oktober 2011 10:39
> Till: mapguide-users at lists.osgeo.org
> Ämne: [mapguide-users] zoom to extent using bookmarks
> Hi!
> I’m running MapGuide 2.1 on windows server 2003 R2 enterpriseX64 and maestro
> 3.5.
> I want to create “Bookmarks” in the task pane  or in the map menu. Just a
> simple invoke URL to zoom to a certain extent within the Map in the same
> session.
> I know that in MapGuide 2.2 you can save an url to your current extent and
> this could be a solution. But I don’t want to upgrade at this point. And I
> also want the bookmark to open in the same session without loading a new
> window.
> Can anyone please give me some pointers
> /Peter von Barth
> mapguide-users mailing list
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
