[mapguide-users] Re: Spatial Query
Martin Morrison martin.morrison at edsi.com
Fri May 25 12:48:14 EDT 2012
In addition to Steve and Gordon's comments, you might want to consider how you are storing the data.  This is another reason why one of the true databases (SQL Server, Oracle, MySQL, etc) would be helpful.  They have builtin functions to do as you describe.  You could get your point from Mapguide, query the database directly to find out the polygon it is in, then display the results in Mapguide.
Martin Morrison
Application Engineer
Engineering Design Systems, Inc.
3780 Peters Creek Rd Ext SW
Roanoke, VA  24018
540.345.1410
gis.edsi.com
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Steve G
Sent: Friday, May 25, 2012 12:00 PM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Re: Spatial Query
Like Gordon said, there is not an out of the box function.  If you are new to MGOS, I would recommend reading through the developer's guide, Chapter 4 (Querying Feature Data) and Chapter 6 (Analyzing Features>Temporary Feature Sources and Creating a Buffer).  While the buffer may not be exactly what you want to do, it may be a starting place.  Also, the samples (php or .net) that you can download may be a good starting point for what you want to do
(also referenced in the developer's guide).
Steve
View this message in context: http://osgeo-org.1560.n6.nabble.com/Spatial-Query-tp4976825p4976992.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
