[mapguide-users] MGOS 2.4: Unable to connect to WMS server
Zac Spitzer zac.spitzer at gmail.com
Mon Nov 19 19:10:00 PST 2012
ArcGIS and Maestro are probably automatically picking up the windows
system proxy settings,
something which might need to be filed as an enhancement request for the various
FDO providers which use cURL
in the meantime, you can set an environment variable
HTTP_PROXY=http://127.0.0.1:8080
which cURL would pick up...
On Mon, Nov 19, 2012 at 7:08 PM, von Wartburg, Jan BKSD
<Jan.vonWartburg at bl.ch> wrote:
> Thank you Zac, for pointing that out: It must be a proxy issue on my network, because I'm not able to connect to a WMS outside of my network with Maestro, although I can display the GetCapabilities in the browser of the server.
> I was just confused that I can access all WMS servers outside of the network with ArcGIS (running on the same server), which has apparently the permission to reach all WMS servers.
> Regards,
> Jan
> P.S. Thanks for the hint, Jackie! With the interactive mode and Fiddler I could clearly see how the access to the outside WMS servers is being blocked.
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
> Sent: Monday, November 19, 2012 8:23 AM
> To: MapGuide Users Mail List
> Subject: Re: [mapguide-users] MGOS 2.4: Unable to connect to WMS server
> are you able to open a browser on the server and access that site?
> do you have a mandatory proxy server on your network?
> the error message is quite clear, "Unable to connect to the host."
> mapguide simply cannot reach the remote server
> On Mon, Nov 19, 2012 at 6:20 PM, von Wartburg, Jan BKSD <Jan.vonWartburg at bl.ch> wrote:
>> In the meantime I have checked several other public WMS 1.3.0 servers
>> with no success. There's always the same error message.
>> Can anyone confirm that WMS 1.3.0 connections are possible with 2.4
>> when using Maestro?
>> Regards,
>> Jan
>> ________________________________
>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of von
>> Wartburg, Jan BKSD
>> Sent: Friday, November 16, 2012 10:06 AM
>> To: 'MapGuide Users Mail List'
>> Subject: [mapguide-users] MGOS 2.4: Unable to connect to WMS server
>> Hi All,
>> I have some trouble connecting to a public WMS server in Maestro:
>> Unable to connect to the host (see below).
>> The URL is http://wms.geo.admin.ch?
>> This is a WMS 1.3.0 server, but MGOS 2.4 does support 1.3.0 I think. I
>> can connect to this server with ArcGIS 9.3.
>> Has anyone got an idea?
>> Regards,
>> Jan
>> System:
>> Win XP, MGOS 2.4, Maestro 4.0.3
>> FDO Connection Status:
>>  Der Remoteserver hat einen Fehler zurückgegeben: (559) MgFdoException.:
>> An exception occurred in FDO component.
>> Error occurred in Feature Source
>> (Session:e096d706-2fc9-11e2-8000-001b388b0f3e_en_MTI3LjAuMC4x0AFC0AFB0AFA//6cd506dc-6c4d-4f2c-ae57-0ccd25be7734.FeatureSource):
>> - MgFdoConnectionManager.Open() line 333 file
>> c:\mg-2.4-x86\mgdev\server\src\common\manager\FdoConnectionManager.cpp
>> - MgFdoConnectionManager.CacheFdoConnection() line 1099 file
>> - MgFdoConnectionManager.Open() line 1091 file
>>  (Cause: , Root Cause: )
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> Zac Spitzer
> Solution Architect / Director
> Ennoble Consultancy Australia
> +61 405 847 168
Zac Spitzer
+61 405 847 168
