[mapguide-users] MapGuide Maestro 5.0 beta 5 and 4.0.4 maintenance release available
Jackie Ng
jumpinjackie at gmail.com
Tue Nov 20 18:17:19 PST 2012
Hmmm, looks fine on my Windows XP test machine.
Firstly, check if you can run the Live Map Definition Editor from the Start
Menu or double clicking the Maestro.LiveMapEditor.exe in the Maestro install
directory under Program Files.
If that works, check that the path to Maestro.LiveMapEditor.exe is correct
under Tools - Options
A command prompt flashing is most likely the UAC-elevated LocalConfigure.exe
registering mg-desktop for available use under Maestro. This always happens
on the first time a freshly installed copy of Maestro is run. If it happens
more than once, then it would be strange.
- Jackie
View this message in context: http://osgeo-org.1560.n6.nabble.com/MapGuide-Maestro-5-0-beta-5-and-4-0-4-maintenance-release-available-tp5017405p5017782.html
