[mapguide-users] Help needed on data migration for MapGuide
Steve G
stevenlgolden at gmail.com
Wed Sep 26 13:15:03 PDT 2012
PostGIS/PostgreSQL has a shapefile loader GUI based off of shp2pgsql. It
should be an plug-in for PgAdmin. I believe the latest release improved the
shapefile loader so that you could load multiple files at once. You should
also do a web search on shp2pgsql for command line options to load
shapefiles. Paul Ramsey blogs about a way to load a mass a shapefiles:
http://blog.cleverelephant.ca/2007/05/mass-shape-file-load-into-postgis.html
I think there is something similar for mysql (shp2mysql) but have never used
it.
-Steve
View this message in context: http://osgeo-org.1560.n6.nabble.com/Help-needed-on-data-migration-for-MapGuide-tp5004758p5004761.html
