[mapguide-users] reading and editing SDF data with java
Zac Spitzer zac.spitzer at gmail.com
Wed Apr 3 18:35:32 PDT 2013
You don't edit SDF data directly, Mapguide uses FDO which is an abstraction
layer for accessing spatial data using a common api...
think of it like ODBC/JDBC for spatial database access.
So once you have created a feature source containing your SDF file,
you then use the resource API methods to manipulate the data.
The API docs has lots of code samples, some in Java, but a lot in PHP
On Thu, Apr 4, 2013 at 12:43 AM, cremebrulee <mazda327 at mailinator.com>wrote:
> I am relatively new to MapGuide open source technology. I would like to
> parse
> and modify feature source data that is in SDF format so that my map
> displays
> this updated feature data (dynamically). How can i do so? I have MapGuide
> installed and configured on Linux. I went through the MapGuide Web API
> documentation but there were no examples on how to manipulate SDF data.
> Currently i am generating the SDF data in a Windows OS environment by using
> FME scripts to query a spatial database and the query generates SHP files.
> I
> then transform those SHP files into SDF files using FME scripts again
> before
> transferring them to the mapguide server repository in the Linux OS
> environment. On the Windows OS end, I am able to edit the SHP files (in
> particular the dbf file just using a spread sheet) to change the values for
> the particular feature source. However this process is static and so i was
> hoping to be able to do so programmatically (using java / jsp) by parsing
> the SDF files for the particular feature source in the Linux domain.
> Thanks
> -mapguidenoob
> http://osgeo-org.1560.n6.nabble.com/reading-and-editing-SDF-data-with-java-tp5044300.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
+61 405 847 168
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20130404/7be7f26b/attachment.html>
