[mapguide-users] mapguide 2.4 sql server spatial feature source - can't select the data store and can't use join extensions
Jackie Ng jumpinjackie at gmail.com
Tue Mar 12 05:24:03 PDT 2013
Here's a workaround you can try:
Create a second feature source (B) with the same connection parameters as
feature source (A)
Create an extended feature class in either Feature Source A or B that joins
to the same table from the *other* feature source.
This way the optimization check that MapGuide does (does both sides of the
join originate from the same feature source?) will fail and the default
Feature Join behaviour is used instead of the buggy RFC123 behaviour.
- Jackie
View this message in context: http://osgeo-org.1560.n6.nabble.com/mapguide-2-4-sql-server-spatial-feature-source-can-t-select-the-data-store-and-can-t-use-join-extenss-tp5033688p5039894.html
