[mapguide-users] MapGuide Maestro6.0a3 and Raster.
Berg, James
James.Berg at stantec.com
Mon Jul 21 13:06:32 PDT 2014
Let's see.
I used MapGuide 2.4 and you're using MapGuide 2.5. Between those versions FDO wasn't upgraded. What worked for me should work for you. The only difference is you're using 64-bit; that will require different binaries.
Try this set of binaries: http://www.gisinternals.com/sdk/PackageList.aspx?file=release-1600-x64-gdal-1-9-0-mapserver-6-0-1.zip
That's for MapGuide 2.4 (64-bit) which should also work for 2.5. That set was posted by Trevor Wekel in this thread: http://osgeo-org.1560.x6.nabble.com/Step-by-Step-for-ECW-and-MGOS-2-4-td4995445.html#a4995528
Download the zip and find + copy the dlls to these locations in your install:
Server\bin\libecwj2.dll
Server\bin\lti_dsdk_dll.dll
Server\bin\gdalplugins\gdal_ECW_JP2ECW.dll <-- don't need that unless you also want ECW (which requires additional steps anyway)
Server\bin\gdalplugins\gdal_MrSID.dll
Server\Fdo\gdal16.dll <-- this one is called "gdal19.dll" now because 2.4/2.5 uses gdal 1.9
Server\Fdo\geos_c.dll
Server\Fdo\iconv.dll
Server\Fdo\libcurl.dll
Server\Fdo\libexpat.dll
Server\Fdo\libpq.dll
Server\Fdo\libtiff.dll
Server\Fdo\proj.dll
Server\Fdo\spatialite.dll
Server\Fdo\xerces-c_2_8.dll
Server\Fdo\zlib1.dll
That list is found here: http://trac.osgeo.org/mapguide/wiki/MGOS22GdalProvider
Be sure to back up your bin folder first in case this doesn't work.
