[mapguide-users] 64-bit woes
Hans Milling hm at geograf.dk
Thu Mar 27 00:53:24 PDT 2014
Are you using Visual Studio? Go to the Debug menu and select Exceptions. Then
at the Common Language Runtime Exceptions mark in the checkbox "Thrown".
This will notify you of any exceptions that might happen behind the code.
You can also try to step trough the code.
If you pull the Maestro5 source code, there is a SignMapGuideApi project
that you can use where the code has been updated.
Best regards
  Hans Milling...
View this message in context: http://osgeo-org.1560.x6.nabble.com/64-bit-woes-tp4182647p5131427.html
