[mapguide-users] tooltips in 2.6 (migration from 2.2. to 2.6)
Andrew DeMerchant andrew.demerchant at gemtec.ca
Wed Nov 5 04:52:18 PST 2014
Any one have any ideas about the tooltips? I'm 0 for 2 right now on
these questions...I can live with the new selection method, if need be.
The tooltips problem is a deal breaker for me, though. If I can't get
that solved, I've got to stick with 2.2 (again - sadly).
On 14/10/28 5:01 PM, Andrew DeMerchant wrote:
> I'm testing out some of my old MGOS 2.2 projects in 2.6 and one
> problem I'm having so far is that some of my more fancy tooltips don't
> seem to be showing up anymore. I've got some tooltips that show
> iframes with some dynamic content (depending on the data that you're
> hovering over). None of these are working in either Fusion or AJAX
> using 2.6...no idea why. What's more, none of my tooltips work at all
> (even the simple ones) in Fusion.
> As a side note, I'm noticing that selecting using the ajax viewer in
> 2.6 seems require that you draw a box around the object, rather than
> just clicking on it...any way I can change that back to the old way?
> Fusion seems to let you click - but not the viewer. I suppose that if
> I get the tooltips working in Fusion, then maybe I will finally be
> able to get rid of the ajax viewer - jury's still out on that though.
> Andrew
> GEMTEC Email Signature
> GEMTEC Limited <http://www.gemtec.ca/>
> *Andrew DeMerchant*
> tel: 506.453.1025  /  toll-free: 1.877.243.6832
> fax: 506.453.9470
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
*Andrew DeMerchant*
fax: 506.453.9470
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20141105/40d7072d/attachment.html>
Name: not available
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20141105/40d7072d/attachment.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20141105/40d7072d/attachment-0001.png>
