[mapguide-users] strange alias problem with gdal (x64)
Andrew DeMerchant andrew.demerchant at gemtec.ca
Wed Nov 19 09:16:38 PST 2014
Yes, that's exactly what I'm looking to do...this definitely worked fine
in 2.2. Any idea if this is only broken in 2.6? I'm not able to build my
own version, so I'm at the mercy of the released versions. As it stands,
I've run into the sid/ecw problem now with 2.6 (the lack of dlls), so
I'm contemplating switching down to 2.5 - but if 2.5 also can't handle
this, I'm sol and stuck with 2.2, I guess.
On 14/11/19 12:30 PM, Jackie Ng wrote:
> If you're are using a configuration document with aliased paths inside, it
> doesn't work. The configuration document that the GDAL provider should see
> should have all the MG_DATA_PATH_ALIAS bits all properly substituted by
> MapGuide. This error messages suggests this problem I just described.
> Whoever said aliased configuration documents worked was lying or
> misinformed.
> There's a patch I haven't yet applied that should allow for this:
> http://trac.osgeo.org/mapguide/ticket/2433
> - Jackie
> View this message in context: http://osgeo-org.1560.x6.nabble.com/strange-alias-problem-with-gdal-x64-tp5173823p5173836.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
GEMTEC Email Signature
GEMTEC Limited <http://www.gemtec.ca/>
*Andrew DeMerchant*
tel: 506.453.1025  /  toll-free: 1.877.243.6832
fax: 506.453.9470
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20141119/bb439955/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20141119/bb439955/attachment.png>
