[mapguide-users] Problems with base layers.
maherich
maherich at gis-services.sk
Thu Dec 22 04:37:47 PST 2016
We didn't dig very deep into it as we didn't have so much time. What we did is that we created two maps:
1. One for public where we put all the layers into one Basemap that is not transparent. So even though the previous maps are loaded after switching the map they are displayed under the map that is selected :). Of course this is only a hack and not a solution. And we transfer lot more data as needed.
2. Second map for authorities. In this map we use no Base Layers anymore. It is not so fast, but there is no problem with switching of maps.
Thank you for your input. If you find any solution, we will very appreciate it.
Martin
From: RenoSun [via OSGeo.org] [mailto:ml-node+s1560n5300545h58 at n6.nabble.com]
Sent: Monday, December 19, 2016 9:17 PM
To: Martin Herich <maherich at gis-services.sk>
Subject: Re: Problems with base layers.
Hi Martin,
Same here with AIMS 2014. I noticed that when I switched the map by using Map Fusion.Widget.MapMenu, somehow the Fusion was still trying to load every maps that I switched to as basemaps, and also the Base Layers from previous maps.
I switched to three different maps, and Fusion request the single tiles of every map that I switched to all the time.
[Header]
[Cookies - PHPSESSID]
[Property Map - Initial Map of Fusion]
[Utility Map - One of the maps of Fusion]
[Recreation Map - One of the maps of Fusion]
I will keep digging for solutions, but hope others may find the solutions for this problem too.
Cheers
If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1560.x6.nabble.com/Problems-with-base-layers-tp5298092p5300545.html
To start a new topic under MapGuide Users, email ml-node+s1560n4182607h80 at n6.nabble.com<mailto:ml-node+s1560n4182607h80 at n6.nabble.com>
To unsubscribe from Problems with base layers., click here<http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=5298092&code=bWFoZXJpY2hAZ2lzLXNlcnZpY2VzLnNrfDUyOTgwOTJ8LTg5MzA4MTUzMw==>.
NAML<http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
View this message in context: http://osgeo-org.1560.x6.nabble.com/Problems-with-base-layers-tp5298092p5301046.html
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20161222/ec9f3015/attachment.html>
